Vibration at high speeds
Old 09-29-2007, 10:09 AM
shane7209's Avatar
shane7209
shane7209 is offline
Hello all,
I purchased a 2003 F-150 Screw a few months back. Within a week I noticed a noise that sounded like a bad ujoint. To it to a shop and they confirmed it. They told me they replaced both. I only drive about 4 miles to work around 40 mph. Friday I had to go out of town and this was the trucks 1st road trip. I noticed that around 55 the truck feels fine. At 65 there is a shake / vibration. At 75 it is very noticable. At 1st I though front end, but after a few hour I noticed the feeling can be felt in the seat of my pants type of thing. Or my foot on the kicker panel. Truck has 27K on it. Any thoughts?
Thanks
Old 09-29-2007, 10:54 AM
kharmaguru's Avatar
kharmaguru
kharmaguru is offline
First things I'd check:
Tires. Aggressive tread and high load rated tires sometime get wild at high speeds.
Wheel balance. Sometimes you lose a weight and it doesn't become noticeable till high speeds. Also you can ask for double balancing, where they balance it then spin it again and fine tune by adding more weights.
Old 09-29-2007, 11:18 AM
shane7209's Avatar
shane7209
Thanks,
The tires are still the factory ones and look to be in good shape. I thought maybe they did not change both ujoints so I took a look. They are both new. I did notice the weights they used are something I have never scene before. Look like peel and stick....... I just can't see that holding up.
Old 07-18-2013, 11:28 AM
tatedog's Avatar
tatedog
tatedog is offline
viration at 73 and up
Shane I know this is old, did you fix your vibration problem in your 2003? thanks
Old 07-18-2013, 01:52 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
Vibration from tire balance or defect in the front often is felt in the steering.
Problem in the rear is often felt in the seat as a general shake because there is no other way to feel it.
Brake issues can play funny games as well.
Motor mounts and trans mounts.
Good luck.
McStein
1983 - 2012 Ranger & B-Series
01-11-2017 11:31 AM
Nunez57
1999 to 2016 Super Duty
13
03-18-2014 01:35 PM
Gomer1
05-23-2011 02:40 PM
Frankievespa
01-31-2011 07:43 PM
JW 4x4
01-22-2002 02:58 PM
Quick Reply: Vibration at high speeds
