new engine
Old Sep 28, 2007 | 08:41 PM
parrisw's Avatar
parrisw
new engine
Haven't posted in a long while. Anyway, my 1990 F250 4x4, was getting sick. So I pulled the engine to freshen it up a bit, and it was way worse off then I orignally thought. So now I ve bought a new Reman long block assy, and now putting that together. Also put in a RV Cam while I was at it. Along with a new clutch, slave cyl, engine mount's.
Old Sep 28, 2007 | 09:22 PM
lostin90s's Avatar
lostin90s
It ussually works that way. Even if not bad it the need of other cam the well if I do that I may as well do this . and the money ball is a rolling.
You'll have a solid ride when done good luck
Old Sep 28, 2007 | 09:32 PM
parrisw's Avatar
parrisw
Yes the might as well's. But I had to do the other stuff. The clutch was worn down to the rivits, motor mount was seperated. And might as well do the slave cyl, since its the internal type, and with my luck it will leak after its all back together, then I will have to pull the tranny to do it, so might as well do it now.
Old Sep 30, 2007 | 08:29 AM
big red c222's Avatar
big red c222
I have a 91 I was thinking about doing the same thing. Let us know how you make out. Mine is a 5.0 Could you answer a few questions? What size motor? Where did you get it? What did you spend?
Old Sep 30, 2007 | 10:43 AM
parrisw's Avatar
parrisw
My motor is a 5.8. I got it from Napa auto parts. And well the price. Since I am a auto mechanic. And the shop where I work has the largest account with Napa, they give us very good deals. And even better deal when I am getting something for myself. I paid $1680 for a reman long block.
Old Sep 30, 2007 | 10:58 AM
big red c222
I was thinking about swapping my 5.0 for a 5.8
Old Sep 30, 2007 | 02:16 PM
parrisw's Avatar
parrisw
That would be a good swap, Im sure its been done many times before. You probably will have to change a few things though.
Old Oct 6, 2007 | 09:01 PM
parrisw's Avatar
parrisw
Well got the engine in and running. Runs great, sounds good. Just have to take it to work to set the timing then she's all done.
YIPEEE
Will
Old Oct 6, 2007 | 09:20 PM
big red c222
Awesome. I guess you will be babying that thing for a little while till it's broke in ?
Old Oct 6, 2007 | 10:02 PM
parrisw's Avatar
parrisw
Yes for sure, probably at least 5000km. Thing is I hardly drive it, cause its not so fuel efficient. I drive a 92 Suzuki Swift as my daily driver. So I will have to buck up and drive the truck for a while. Definatly need to put some miles on it before I pull my 5000lb travel trailer.
Old Oct 7, 2007 | 03:01 PM
parrisw's Avatar
parrisw
Set the timing today, and took it for its maiden voyage. Runs awesome, its so much better then it was before.
