1978 - 1996 Big Bronco
abs testing on a 96
Old Sep 28, 2007 | 08:01 PM
96bronco58's Avatar
96bronco58
abs testing on a 96
Question about testing the abs system. I think I jumpered the test plug correctly black wire to black blue under the hood. But after doing this the abs light does not flash. It just stays lit. The light came on the other day for no apparent reason had driven about 30 miles and turned it off then restarted and abs came on and stays on constantly. Am I jumpering the correct pins on the test port under the hood or is it possible I have a problem with the abs module.
Old Sep 29, 2007 | 12:51 PM
96bronco58's Avatar
96bronco58
double checked how i jumped the test connector and I had i correct but the abs light still does not flash a code it just stays on. Anyone have any thoughts as to the possible cause?
Freddie Murphy
Jul 7, 2016 02:19 PM
JustFixIt
Aug 5, 2015 04:21 PM
Wamphyri
Sep 8, 2014 06:59 PM
tjc47
Feb 6, 2014 12:22 PM
4x4 ranger guy
1983 - 2012 Ranger & B-Series
Dec 5, 2004 04:21 PM
