Sponsored by: Auxito
Trans Range Sensor Problem
Old Sep 28, 2007 | 07:29 PM
gold101's Avatar
gold101
Angry Trans Range Sensor Problem
I have a 97 F150 4X4 with a 4.6L. It is bringing up a code in the computer saying high trans range sensor input. I swapped the TRS, but it still reads the same code. I need to get this truck inspected and they will not do it if the light is on.
John
Old Sep 30, 2007 | 10:58 AM
AzBlueWolf's Avatar
AzBlueWolf
check the wiring to the trs and any nearby grounds for bad connections
Old Sep 30, 2007 | 01:04 PM
Wilber15's Avatar
Wilber15
Check the reference voltage feed into the TR sensor. I believe it is a 5V reference(but check to be sure). also check for a good ground. You could have a wiring short to a higher voltage in the harness somewhere. If you have the ability to hook a scanner up to it, read the TR voltage the module is seeing.
Old Sep 30, 2007 | 03:29 PM
gold101's Avatar
gold101
I appreciate the advice. I am still trying to track it down. The voltage from pin 64 on the computer is 5.09. I even disconnected the thing and is still read high input. I am not sure what the problem is. I had to build the engine harness so now I am looking at that to make sure I did not get something crossed.
Old Oct 20, 2007 | 09:20 AM
slippinout10's Avatar
slippinout10
i have a 99 ford f-150 that did yhe same thing, had to go to dealer ship and have a new key made .they said key has a chip in it.it worked on mine.cost about 75.00 >>>>>>>>slippinout10
Old Oct 20, 2007 | 06:09 PM
projectSHO89's Avatar
projectSHO89
..and this has what to do with a TRS fault code problem?
Old Oct 20, 2007 | 09:22 PM
slippinout10
it was not the trs sending the code but lose of power or a power surge through the pcm,sending a false code. sounds like stupid needs to be educated before it becomes ignorant!!
jgilrfr
Jan 30, 2012 06:06 PM
jrar
Bronco II
Apr 7, 2005 10:39 AM
jvaski
1997 - 2003 F150
Dec 26, 2004 06:01 PM
Rubbersoul
Mar 24, 2004 10:11 AM
