Ok I took my gauge cluster out to replace a few bulbs that were burned out. (vehicle in sig).
Now there are 5 large "194 bulbs", that are to illuminate the gauge cluster itself.
Then there are 17 smaller "37 bulbs", that illuminate random things.
In the middle of the gauge cluster, (in between and a bit lower to the left/right signal bulbs) there is another bulb. The twist thing for it is a different color (white instead of tan). The bulb is a little shorter and a bit fatter, but I have no idea what number it is, it is rubbed off.
Anyone know what bulb number that is? The cluster itself just says 96jp bulb, but that is it, and I can't find a bulb that is numbered 96. Anyone have any ideas? I was trying to order the bulbs online, since autozone wants $1.25 per bulb (and online they are $0.52 cents each).
