Here we go again.
Old Sep 28, 2007 | 02:46 PM
WonderDonkey's Avatar
WonderDonkey
Here we go again.
So i have a p1316 code, and from what i have seen this code could be anything but upon futher investigation i have also oncovered p1204 and p1205 codes. #4 and 5 open/shorted. I only get an ses light flash intermitant after the truck sits and cooled down until my needle os dead on C. any suggestion?
Old Sep 28, 2007 | 04:20 PM
John311t's Avatar
John311t
Check your under valve cover gaskets. Look at the electrical connectors and see if they are chaffed or burned just make sure they look correct.
Old Sep 28, 2007 | 04:21 PM
WonderDonkey
Sorry i have checked the uvc several times and all looks good with them, i have also ohmed the uvc out and all were below 5 ohms. whats next?
Old Sep 28, 2007 | 06:13 PM
UcaN's Avatar
UcaN
I had a similar problem as well, with the dreaded 1316. I checked everything over a dozen times, changed uvc harnesses, gaskets, ohmed everything including the main connector over the drivers side VC, to and from the IDM. I just about gave up, because everything checked out fine on the ohm meter.
Finally i decided to trace every single wire leaving the VC gaskets (outside plug). One of the wires from the passenger side that leaves the outside connector was rubbing against the engine and had BARELY chaffed enough to cause a short. It was weird because it could run fine for a whole week then suddenly it would loose a cylinder and pop a 1316. The chafe was so small that i literally had to put a flashlight real close to it to see it......
I would suggest checking every wire going into the gaskets.....
Old Sep 28, 2007 | 06:35 PM
greedy737's Avatar
greedy737
What is a zoodad ????
Old Sep 28, 2007 | 07:25 PM
Action4478's Avatar
Action4478
That bug is working ...
Now I know why they call them bugs....
Old Sep 28, 2007 | 07:29 PM
Action4478's Avatar
Action4478
Putting a hole in the rad support to aid the flow of air to the filter.......
