how do i know
Old Oct 2, 2007 | 03:07 PM
powerstrokeddiesel's Avatar
powerstrokeddiesel
well i just now found a dual mass replacement clutch for my truck for $$$304.00 what should i do???
Old Oct 2, 2007 | 05:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You should skip it. Sooner or later your flywheel is going to be the issue. Might as well go solid now since you'll have it down for the clutch and be done with it.
Old Oct 2, 2007 | 06:04 PM
Neal 97 250's Avatar
Neal 97 250
I strongly agree skip it. if it were me the flywheel would go out as soon as I did the clutch. Also I don't think you can turn the DMF. At least I wouldn't.
Old Oct 2, 2007 | 06:42 PM
1997F-350's Avatar
1997F-350
I READ YOUR SIGNATURE.......soon to have stage 2's and then i stopped reading. get a good single mass clutch from southbend or luk. then you will be ready for the fuel.
Old Oct 2, 2007 | 07:48 PM
Neal 97 250
Yes with those mods definately get a SMF.
Old Oct 2, 2007 | 08:10 PM
powerstrokeddiesel
thanks guys and sorry it took so long for me 2 reply again i was at fire schooling and i believe i will do the solid flywheel
Old Oct 2, 2007 | 08:36 PM
Neal 97 250
Good decision.
Old Oct 2, 2007 | 09:08 PM
powerstrokeddiesel
i hope so especially cause it will cost me more
Old Oct 2, 2007 | 09:20 PM
Neal 97 250
nd you will be Very much happier.
Old Oct 2, 2007 | 10:45 PM
61 uni's Avatar
61 uni
This is all that you need. It is what is in my truck now.
http://www.carolinaclutch.com/ShowItem/110408.aspx
Old Oct 2, 2007 | 11:55 PM
andywe's Avatar
andywe
A couple of things...why does he need to buy both when it seems the SMFW kit comes with the clutch kit at a lesser price? Kit 07-154/1 comes with the clutch and flywheel where the other kit mentioned says complete kit, but then the description states to use the solid flywheel kit.
I would give Carolina a call and confirm before ordering both. Ir ecall the whole thing was once quoted (Inc. cylinders and fork) for around $700.00 and think the site may not be accurate in it's descriptions.
Old Oct 3, 2007 | 10:19 AM
powerstrokeddiesel
do u all think i really need a new slave cylinder and clutch forks???
Old Oct 3, 2007 | 10:59 AM
  #28
61 uni's Avatar
61 uni
I wouldn't replace anything except the clutch and flywheel. If you get in there, if the fork is broke then replace it. Don't throw money at it. Only replace what you have to.
Old Oct 3, 2007 | 11:07 AM
  #29
powerstrokeddiesel
ok just making sure i did not need anything else
Old Oct 3, 2007 | 12:12 PM
  #30
Neal 97 250
I don't think the slave cylinder is that expensive. Then again it has been awhile since I did mine. I would do that anyway. just my opinion.
