unplug the spout ?
Old Sep 28, 2007 | 11:04 AM
92fordman's Avatar
92fordman
unplug the spout ?
i read that it doesnt hurt the engine if the spout is unpluged.because my truck runs rough no matter what i do cleaned the throttle body the egr and replace the sensor no vacuum leaks and replaced the IAC and ran the plug wires away from each other.and the idle isnt steady it up and not a lot but a little.and it runs down the run road fine need help
Old Sep 28, 2007 | 11:11 AM
EPNCSU2006's Avatar
EPNCSU2006
If you unplug the SPOUT connector, the engine will run at the base timing advance all the time. This might help with the idle slightly, but it will make the engine gutless at all points other than idle, and could cause higher than normal exhaust and engine temperatures if operated at base timing for a long enough period of time.
Old Sep 28, 2007 | 11:18 AM
quicklook2's Avatar
quicklook2
wires and cap/rotor should be replaced.
not using the spout is a band aid repair.
you know a band aid never stays on for too long.
find and fix the problem.
read codes.
reset computer.
Old Sep 28, 2007 | 11:23 AM
92fordman's Avatar
92fordman
the check engine light isnt on and the cap and rotor are new
Old Sep 28, 2007 | 11:29 AM
quicklook2's Avatar
quicklook2
the light does not have to be on to have a set code.
the wires may be the problem.
what brand cap/rootr? brass?
plugs are what brand and kind?
Old Sep 28, 2007 | 12:23 PM
92fordman's Avatar
92fordman
autolite wires and i put wire condute on them it has an msd cap and rotor and it has champion plugs platnum plus
Old Sep 28, 2007 | 12:25 PM
quicklook2's Avatar
quicklook2
the champion platinum plus plugs are probably the problem.
buy a set of motorcraft copper resistor plugs and i bet you the problems go away.
also, in the future it helps to say what engine/trans combo you have in your post.
Old Sep 28, 2007 | 12:29 PM
92fordman's Avatar
92fordman
why would that be the the problem?
Old Sep 28, 2007 | 12:31 PM
92fordman's Avatar
92fordman
its a 92 f150 5.0 a4od
Old Sep 28, 2007 | 12:32 PM
Skandocious's Avatar
Skandocious
Tons of guys here on FTE have reported having lots of problems with platinum plugs, for some reason these trucks don't like them. Pull the plugs and check to see if they are fouled.
Old Sep 28, 2007 | 12:38 PM
92fordman's Avatar
92fordman
what plugs should i get for it i couldnt get motorcraft plugs they didnt have them i want a set to last a while
Old Sep 28, 2007 | 12:41 PM
Skandocious
Motorcraft is your best bet. You can try the dealer or if you want to wait a few days it would probably be cheaper to order them from rockauto.com. I ordered mine from there and was very satisfied with my purchase, quick shipment too.
I've also heard that copper autolites work fine too.
Old Sep 28, 2007 | 12:52 PM
92fordman's Avatar
92fordman
i have a friend with a ford 150 with a 4.9 and he put bosh plugs in it and it runs fine
Old Sep 28, 2007 | 01:11 PM
Skandocious
My truck was running bosch platinums without problem either when I bought it, so it seems that it's not every truck. All I know is that I've seen plenty of guys here with brand new platinum plugs that made their trucks run awful.
Old Sep 28, 2007 | 01:22 PM
quicklook2's Avatar
quicklook2
you can find motorcraft plugs if you shop around.
if you try any kind of platinum plugs and they work for you, fine.
if you have platinum plugs and you are having trouble, remove them and put in regular old motorcraft copper resistor plugs.
