Sponsored by: Kumho
ABS sensor
Old Sep 28, 2007 | 04:55 AM
windstarharv's Avatar
windstarharv
ABS sensor
I have a 98 Ford Windstar. I exchanged a right side spindle with one I picked up from the junk yard. Now I have my ABS light on and the Trac Off light flashing. Can the ABS sensor be removed from the spindle and replaced with the one in the spindle I took off? How do I remove it if so?
Old Sep 28, 2007 | 07:10 AM
ubereal2's Avatar
ubereal2
You should see the sensor at the spindle. It should have a small bolt head, about an 8mm or so. Remove the bolt, probably have to wiggle it side to side a few times to free it up and get it out. Fallow the wire back and un-plug.
Bob
Old Oct 14, 2007 | 01:35 PM
mudmentwo's Avatar
mudmentwo
I Have The Same Problem I Replaced The Pass Side Hub And Now My A B S Light Comes On Did You Ever Get It Figured Out Thanks John
Old Oct 15, 2007 | 07:30 PM
windstarharv
I haven't really had time to mess with it. This is the 3rd time I replaced the hub and spindle but the 1st time I had a problem with the ABS sensor.
uncwgrad1
Dec 30, 2009 11:48 PM
RhinoScores
1978 - 1996 Big Bronco
Mar 9, 2009 06:29 AM
yellott
Oct 18, 2006 08:20 AM
jimmc
15
Sep 11, 2004 10:53 AM
