Can't remove fuel filter!
Old Sep 27, 2007 | 10:19 PM
mike L's Avatar
mike L
I'm using the metal sizzor tool to remove my fuel filter, but i can't get the rear line loose. Can the fuel removing plastic tool work better? I used wd 40 on the front line, it came off after doing that.
Maybe it's got dirt in the end so the sizzor removal tool wont work on the back end of the fuel filter. I can get the tool all the way in and the line moves back and forth, on the filter, but it wont unhook.
Any tips?
Old Sep 27, 2007 | 10:23 PM
Skandocious's Avatar
Skandocious
If you don't have a second tank up front, like me, it helps to pull the filter OUT of the retaining clip to get that back line off. Otherwise, the trick is to shove the filter and line together as hard as you can, insert the tool, the pull back on the tool as hard as you can.
Old Sep 27, 2007 | 10:26 PM
radialarm's Avatar
radialarm
We had a guy on here the other day that ripped his apart with no tool. I keep several different type tools on hand sometimes one will when the other wont. If all else fails put on a pair of gloves and pull like hell!
Old Sep 27, 2007 | 10:34 PM
Skandocious
If you really get stuck you can always cut the nipple off of the stuck side of the filter (as close to the filter element as possible) and use a pair of pliers on the remaining piece stuck in the fuel line...
Old Sep 28, 2007 | 07:16 AM
Scndsin's Avatar
Scndsin
See my post # 11 in this thread, sounds like your prob. Good luck.
https://www.ford-trucks.com/forums/6...-mechanic.html
seanseamus1
1997 - 2003 F150
Oct 29, 2016 09:59 PM
bkgeig
15
Nov 11, 2010 06:45 AM
ilkefords
Aug 17, 2009 02:32 PM
FLAUSA
Jul 8, 2005 08:08 AM
k4uwc
1978 - 1996 Big Bronco
Mar 15, 2004 05:24 AM
