8BA crankcase capacity
Old Sep 27, 2007 | 10:19 PM
frb9883's Avatar
frb9883
I have an 8BA with the truck style oil pan. How many quarts does it take to properly fill the crankcase? Lost stock dip stick.
Old Sep 27, 2007 | 10:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
5 quarts, regardless of whether or not there is a filter. This is a subject of hot debate!
Old Sep 28, 2007 | 04:22 PM
frb9883's Avatar
frb9883
Thanks...That's what I had. The engine is an 8BA but the dip stick is stamped 8RT. Wanted to be sure I had sufficient oil in the crank case.
Frank
Old Sep 28, 2007 | 05:07 PM
mtflat's Avatar
mtflat
Keep in mind the only thing that distinguished an 8BA from an 8RT was the bolt-on accessories.
Things like oil pan, waterpumps/motor mounts, fans, generator pulley, oil filter location, etc.
Long blocks were the same - some claim the cam was different in the truck, but I've never seen spec sheets for this ...........
So if you've got a good running late flathead, celebrate!! and run it.
Old Sep 28, 2007 | 10:40 PM
kooper909's Avatar
kooper909
Dennis Carpenter lists two flathead cams for 1948-1953 ... 7RT-6252 and EAB-6252. They are not separated by truck/car, though. No matter whether you look up a car or a truck, you see both. I don't know quite what to make of that.
Old Sep 28, 2007 | 10:51 PM
mtflat's Avatar
mtflat
EAB was the prefix for 52/53 flatheads.
