Lift? again
Old Sep 27, 2007 | 10:11 PM
Lee250's Avatar
Lee250
Lift? again
If I was to make my own, or buy the coil spring spacers to lift the front of my truck 1" is there enough camber adjustment or would I have to put a 1" spacer at the end of the I-beams as well? If there is what about 1.5"?
Old Sep 27, 2007 | 10:25 PM
Franklin2's Avatar
Franklin2
They make special bushings to compensate for lift. I think I read on here that you cannot lift it over 2 inches though using just spacers and the bushings.
Old Sep 28, 2007 | 10:31 PM
Lee250's Avatar
Lee250
where can I get that bushing
Old Sep 30, 2007 | 10:47 PM
Lee250's Avatar
Lee250
Anyone know where I can get that bushing?
Old Sep 30, 2007 | 10:50 PM
Franklin2's Avatar
Franklin2
Go to www.partsamerica.com and punch in your truck. I found them there. They have a whole selection with different amount of degrees. I can't remember exactly which section I was in, but try "suspension".
Old Oct 1, 2007 | 10:58 PM
Lee250's Avatar
Lee250
How much degrees would I need for about 1.5" off lift? Would the 4wd ones work on my 2wd?
