1978 - 1996 Big Bronco
Leveling Kit
Old Sep 27, 2007 | 07:46 PM
Trevor1's Avatar
Trevor1
Leveling Kit
I have a 1979 bronco that I want to level, I already have 8.5 inches of lift on the front (3" inch body lift, 3.5 inch spring tower drop, and 2 inch taller coil springs), I need something like a polyurethane spacer. The truck sags because of huge custom bumper, 8,000 pound warn winch, and 460 big block.
Old Sep 27, 2007 | 10:02 PM
blue beast's Avatar
blue beast
I would get different springs they are probably way too soft for the components you got! If you just put spacers in they are going to continue sagging!! If you want to try it make your own out off old 22ply rated truck tires and a sawzall.
Old Sep 30, 2007 | 02:12 PM
dwoodler's Avatar
dwoodler
Weight is definitely your issue - try looking for a pair +2" 3/4 ton springs. Some may say that they will be stiffer and ruin the ride but with all the bumper and motor in the front end they shouldn't be too bad.
Old Oct 1, 2007 | 06:22 AM
polky's Avatar
polky
Depends On Want Looks The Best. That 2" Spacer Doesn't Look The Best, But It Is Cheaper Then Ordering Taller Coils. If You Got 2" Taller Coils, Figure How Much You Need And Order That Much Spring. I Know That Superlift Front Springs Are Really Heavy And Thick In Diameter. Good Luck.
biggyfan1
Oct 18, 2013 10:54 PM
fordman2267
Feb 26, 2010 08:59 AM
DarkNite
Oct 4, 2008 06:30 PM
MuddKinG
1983 - 2012 Ranger & B-Series
Mar 16, 2002 02:47 PM
