i suppose thats calling me out. if not oh well here is my easy install
step one get the horns.
step 2 get a tank- walmart has a 7 gallon for 20 bucks, a bit overkill but they last a really long time
step 3 get some line and brass fittings, and a solonoid, local hardware stores and truck shops, shouldnt cost more than 30 or 40 bucks for it all, 1\4 inch line is minimum but the 5\16 is a huge difference
step 4 mount the crap up, my whole set-up took under an hour, mounted the tank right under the drivers side just rear of the t-case, each horn is under the door mounted in the existing running board hole, wires were just as easy, hot wire ran right from the old horn down to my solonoid and the ground is right on the frame
if you havent seen the pics here they are again
