Smoking 360
Old Mar 8, 2002 | 07:45 PM
1967fordranger's Avatar
1967fordranger
Smoking 360
The 360 I had to put in my truck a couple of months ago is smoking when I start it. Everytime I start my truck I get a cloud of white smoke. It also burns quite a bit of oil. As long as I keep oil in it it runs good. I was wondering what is causing it to smoke.
Old Mar 8, 2002 | 08:08 PM
DrFord's Avatar
DrFord
Smoking 360
I believe Smoking on start-ups is usually a sign of worn valve guides. (someone correct me if i'm wrong) The oilinthe heads leaks past the guides and onto the valve. then when you start it the valve opens and dumps the oil into the chamber
Old Mar 9, 2002 | 02:30 PM
karlsd's Avatar
karlsd
Smoking 360
Smoking on startup can also be a sign or worn rings. As the engine heats up, the pistons and rings expand and seal up better.
Still, blue smoke is typical of burning oil. White smoke usually means coolant/water. I'd suspect a blown head gasket along with possibly bad rings and/or valve guides.
Old Mar 9, 2002 | 02:32 PM
karljay's Avatar
karljay
Smoking 360
Some things to check, PCV system, this helps the rings to seal and helps keep oil from passing the stem seals.
Stem seals, you can actually install new seals without removing the heads with a small rope to hold the valve in place and a tool to remove the springs.
check the amount of oil going to the head, if it floods the head it's probably too much oil and some restrict it with a Holley carb jet under the rocker arm stand.
Check to see if the rocker shafts are not upside down, the oiling holes need to be pointed down. You can remove one of the end rocker arms and look for the oiling hole on the bottom. Some make this mistake when rebuilding the valve train.
A leak down tester or compression test should tell something about the condition of the rings, if it's marginal, either live with oil loss or start looking into a rebuild.
Old Mar 9, 2002 | 06:31 PM
jbhf250's Avatar
jbhf250
Smoking 360
A bad intake manifold gasket will allow oil to be sucked into the intake runners.... Are all the spark plugs showing a sign of burning oil? are they wet?
__JOHN__ô¿õ
1972 F-250
ICQ# 6030753
Old Mar 9, 2002 | 07:59 PM
1967fordranger
Smoking 360
[updated:LAST EDITED ON 09-Mar-02 AT 09:01 PM (EST)]The spark plugs do show signs of burning oil. The piston rings should not be worn because they were replaced not long ago. If the crappy mechanic I used would have called me before he replaced the rings I would have had him check all the valves but he didn't so I don't know what they look like. Since it sounds like it is a pretty big job to fix this I probably won't since I am selling the truck. I was just hoping there was a simple way to get it to quit smoking. And the smoke is actually more of a blue or gray than white.
Old Mar 10, 2002 | 10:17 AM
FE427TP's Avatar
FE427TP
Smoking 360
[updated:LAST EDITED ON 10-Mar-02 AT 11:19 AM (EST)]
than white.
You could try swapping in some thicker oil, like 20w50, I noticed changing from 10w30 to 15w40 stopped a smoking outside of my right pipe (dual exhaust) but it's still better to let the new buyer know the engine will need the stem seals replaced and that it's a fairly easy but time consuming job
Old Mar 10, 2002 | 10:08 PM
canzus's Avatar
canzus
Smoking 360
