<HR style="COLOR: #dddddd" SIZE=1><!-- / icon and title --><!-- message -->Going to put a 351 in my 94xlt regular cab. And want to know if the alt, bracket and Ac/PS brackets are the same, between the 302 and 351?? Just want to make sure, so if I need to get them I can before hand
You use the same computer?? All I plan on doing is swapping the motor. Am getting it out of a 95 king cab.. So after a freshening, want it to be a drop in..
It's been a long time since I did this swap but it runs in my mind I had to switch some brackets due to the 351 being wider. I do recall it being fairly easy and very worthwhile though. Good luck Dave
A '94 302 would not be MAF unless it was converted, so he would need the computer out of the '95. He would probably also want the wiring harness, as the 302 has a knock sensor that the 351 does not. I hope they're both E4OD trannies....
A manual tranny wouldn't be very good, either, because the 351 should really have the ZF behind it, but the 302 didn't get that tranny from the factory, it got the Mazda instead in the rare instances when it got a manual (I can't say I've seen ANY sticks behind gas V8 Fords in these parts).
I used the 351 computer and harness. I kept my M5OD and it has held up so far without issues. Also the truck the engine/computer/wiring came from was a E4OD and I haven't had any problems there.
In a 250, you probably have the ZF.
He was refering to the Mazda 5spd not holding up to the 351. Some say it's not up to the task, others say it will work. Same with the 4R70W and the E4OD trannies.
My truck is a 94 with maf and a 4r70w( trans code U) ... I am looking for a good work horse engine. Something that, if needed tow a car & trailer without breaking a sweat...
"Work horse", go with a 5.8 swap. You will need a flexplate from an 80s grand marquis with 5.8/AOD combo. Comp will run the 5.8. Try to get a complete motor, intake to oil pan. Your y-pipe will have to be modified as well. The 351 is wider.
5.8 should have no prob towing what you need, I was towing a big travel trailer with mine with the old tired motor, and the trailer wiegh's 4360lbs dry.
