Quick leaf spring cross referance please.
Old Sep 27, 2007 | 12:18 PM
yield2s's Avatar
yield2s
Quick leaf spring cross referance please,(Bronco to F-150 4x4)
Will rear springs from 1990 bronco fit my 77 F-150 4x4(3")?
Old Oct 15, 2007 | 08:44 PM
amish77's Avatar
amish77
I think that they do, but only if you have a 77.5. There was a frame difference between pre-80,000 and post 80,000. Check to see if your frame flares before it contacts the bumper, or simply measure the width between the frame rails at the bumper. I think it's 34'' for pre-80,000 and 38'' for post 80,000. Also the springs on the 150 may be 2.5'' springs. If that's the case then forget it. Measure these two widths and if it lines up I'd say try it.
Old Oct 16, 2007 | 01:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The Ford Parts Catalog only shows one rear spring for all the 1975/79 F150 4WD's. The catalog makes no serial number or date change reference for 1975 thru 1979 F150 4WD's.
1975/79 F150 4WD Rear Spring
D3TZ-5560-J
5 Leaf
Width: 3 inches
Length: 31 1/2 inches
Load rate: 1875 lbs.
Source: 1973/79 Ford Light Truck Parts Catalog ~ Rear Spring Application Chart: Section 53; Page 49 & Size Chart: Section 53, Pages 56/57.
Old Oct 16, 2007 | 06:07 PM
amish77's Avatar
amish77
You can check out LMC trucks for leaf spring specs as well. Didn't think of that.
renegade_75
Mar 13, 2013 02:50 PM
tex4431
Mar 15, 2012 08:58 PM
GHeTTo JOe
Dec 31, 2009 05:42 AM
StrokiN&SmokiN
Aug 11, 2008 11:52 AM
