Competition Diesel racing, sleds, dynos, power tuning and max performance.
First Sled Pull! check it out
Old 11-06-2007, 05:54 PM
6.0superduty's Avatar
6.0superduty
6.0superduty is offline
Talking First Sled Pull! check it out
This weekend I competed in my first sled pull. Wasn't sure what to do, so I just put it to the floor. Got 35 swampers and Matt's agg race tune. Made my own hitch and traction bars. I still need to figure out how to start correctly so that my truck isn't hoppin so bad. The track was as hard as asphalt- may have had something to do with it. Anyways, it was awsome!
http://www.youtube.com/watch?v=-9w33Kd8K7I
http://www.youtube.com/watch?v=lyNCnSp28Gw
My buddies 06 Cummins
http://www.youtube.com/watch?v=1L_2hEQsri0
Sweet video my D-Max buddy made
http://www.youtube.com/watch?v=bGh3VxdhYBA
Old 11-06-2007, 06:14 PM
killaford's Avatar
killaford
killaford is offline
wow thats awsome dude.
you did real good on the second run.
i see you spanked your buddies dodge with ladderbars.
man the 6.0 sounded mean.
Old 11-06-2007, 06:24 PM
Kep4's Avatar
Kep4
Kep4 is offline
Jäger
Thanks for posting those links! Your 6.0 sounds real mean.
Have you made any changes to the transmission? I'd try pulling but that's my only concern at this point.
Old 11-06-2007, 06:25 PM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is offline
Received 3,450 Likes on 2,122 Posts
Nice videos
Should be in competition but I will leave it here...
Lift kits and pulling are not the best set up.....not sure what you have but the front end needs to stay low.
Locker up front
Clamp the rear springs, forward of the rear axle
Make a plate from the frame to the spring perch (both sides) with a 1 inch travel, play with the distance. This allows the rear springs to only compress 1 inch and locks the truck down. The sled becomes a good lever to put weight on your truck and the track.
Old 11-06-2007, 06:29 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
Moved enjoy.
Comp guys need to see this ...to cool
Old 11-11-2007, 06:05 AM
thorseshoeing's Avatar
thorseshoeing
thorseshoeing is offline
decadent and depraved
Why are you and the Dodge only running one stack??? I have never seen anybody do that before...
Tim
Old 11-12-2007, 12:23 AM
6.0superduty
Do you ever read the magazine Diesel Power? Everybody has one stack.
Old 11-12-2007, 05:12 AM
thorseshoeing
No...Is there any reason for it? It just looks kinda odd to me...No offence, I'm just use to seeing two...
Tim
Old 11-12-2007, 07:16 PM
6.0superduty
yeah, I guess we are just weird
Old 11-18-2007, 08:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
single stacks are pretty cool. i'm eventually gonna get rid of my haulers in lew of a miter cut 8" single stack. nice job on spankin' the cummins!!!! pretty nice pull for just having the X-CAL2. throw some injectors in that mother and let 'er eat!!
Old 11-19-2007, 10:50 PM
duramaximizer's Avatar
duramaximizer
duramaximizer is offline
The reason for the single stack rather than the double is that the double stack costs hp because you are spliting the air and making unwanted back pressure. Otherwise 2 actually looks better. JMO
FYI, a guy running a T (not a Y) on a 1000rwhp truck found 60 hp just taking the T out and running a single. Where else can you pick up 6% that easy? It would be less with a Y, but the concept is the same.
Old 11-29-2007, 03:36 PM
zpmps2's Avatar
zpmps2
zpmps2 is offline
I saw that in a magazine. Also, if your blowing deep black smoke out of 2 you have to look at both to see the "HELL YA" results, with one its TONS MORE SMOKE AND AN EVEN BETTER "HELL YA"
Old 03-05-2008, 08:56 AM
scottie2hottie's Avatar
scottie2hottie
scottie2hottie is offline
aren't you guys cute with your matching single stacks....LOL. Just kidding, nice work.
Old 04-29-2008, 08:46 PM
heymrdj's Avatar
heymrdj
heymrdj is offline
I wish i could try this with my Expedition for the hell of it, probably blow a rod right through the hood :P.
Old 05-01-2008, 05:34 PM
WALJON's Avatar
WALJON
WALJON is offline
Cool vids bet it was super loud under that steel roof
Quick Reply: First Sled Pull! check it out
