Repairing cab mounts
Old Sep 27, 2007 | 09:40 AM
Unimog005's Avatar
Unimog005
I have a 1967 F-250 "highboy" that is in need of some attention regarding the cab mounts. It appears that some of the metal over the rubber mount (on the underside of the cab) need to be replaced, along with 2 of the side braces that run out to the door sill. Since I do not have a garage or own a wleder....nor do I know anyone that is good with body work....I will need to take this to a bodywork guy to have the work done. How are these jobs priced? My truck is already a "frankentruck" so I am not in need of custome repainting or anything...just need to have the work done....so what sort of prices should I expect? Would it be a good idea to install a body lift kit (just a simple 1.5" thing...to allow bigger tires) at the same time? Would that add alot of extra cost?
Old Oct 15, 2007 | 08:31 PM
amish77's Avatar
amish77
Well the body lift would have to be done to the entire truck, and most guys that do a body lift do them themselves. The labor on this will kill you. The welding shouldn't be too bad, and if you want to get into the fine art of welding this would be a good opportunity. The body mounts are hard to see, so no one will notice where you screwed up. Just make sure you have good enough penetration to hold the cab up.
Old Oct 16, 2007 | 10:31 AM
ToughBuiltFord's Avatar
ToughBuiltFord
FTE Sponsor
Our shop carries body lift kits. You can find some prices and customer reviews here: http://motorhaven.autoanything.com/suspension-systems/61A3002A0A0.aspx?from_search=1
Old Oct 16, 2007 | 03:41 PM
fastmover's Avatar
fastmover
Blue Oval Truck Parts, National Parts Depot, Dennis Carpenter, and other FTE sponsors sell patch pieces for cab mounts. I need to replace them on my '70. Good luck.
cghstrojan08
15
Jul 14, 2010 08:25 PM
ensjanos
Nov 25, 2009 05:23 AM
ford66
Sep 2, 2009 07:01 PM
wiesshund
Mar 19, 2004 06:03 AM
1bad390
Mar 10, 2003 09:16 AM
