Aerostar Ford Aerostar
Front end shake and pull
Old Oct 3, 2007 | 09:16 PM
DOUG5G's Avatar
DOUG5G
After replacing the wheel bearing is an alignment required? I was also planning on doing the Upper control arm bushings and Upper ball joints while had everything apart at the same time.....but my finances have slowed down my grand plans. I am thinking about doing just the wheel bearings this weekend if I don't have to get an alignment.
Thanks
Doug
Old Oct 3, 2007 | 09:20 PM
96_4wdr's Avatar
96_4wdr
no alignment required unless the tires are wearing unevenly, the bearing are badly worn and loose and it was aligned recently with the bad bearings
if the bearings and tires look fairly good, drive it unless you don't trust the ball joints or tie rod ends.
either braking off while on the road can make for a wild ride
Old Oct 4, 2007 | 08:01 AM
Pablo-UA's Avatar
Pablo-UA
No. do nothing.... drive and enjoy
Old Oct 9, 2007 | 01:06 PM
DOUG5G's Avatar
DOUG5G
The final problem ended up being sticking brake calipers. Just wanted to let everybody know if you didn't read brake question string.
https://www.ford-trucks.com/forums/6...ng-evenly.html
AEROMAN59 guessed it right away. Thanks
Doug
Old Oct 9, 2007 | 02:11 PM
VanGo's Avatar
VanGo
Doug
I just read your other thread. I was going to ask if it fixed this problem when I saw your last post here. Looks like it did!
Obxbornfree
Sep 28, 2016 08:36 PM
Blackvan77
Mar 18, 2016 07:24 PM
VTENX
May 28, 2015 03:33 PM
dougbrown
Apr 27, 2012 10:02 PM
AC94EXPLORER
Feb 8, 2008 01:57 PM
