Where is accessory buss???
Old Sep 26, 2007 | 09:43 AM
Capt Jim's Avatar
Capt Jim
Unhappy Where is accessory buss???
I am adding a 60 gal. fuel tank with a transfer pump to my 95 F-250 7.3. Can not find the accessory buss or information on accessory wiring. Need to turn off power to pump switch when key is off.
Also is there a accessory buss or lug under hood? Getting to damn old and fat to get under dash
Thanks
Capt Jim,
Old Sep 26, 2007 | 10:35 AM
tjbeggs's Avatar
tjbeggs
The best thing to do would be to run the pump off a relay that you could signal from an ignition fuse in the fuse panel in the dash. the fuse for the heater controls or radio would be a good signal wire. they make nice little fuse taps then you can run that wire to a relay. then pull power for the pump directly from the battery thru an inline fuse, to the relay then out to the pump.
