Stopping distance ? ? ?
Old Sep 25, 2007 | 11:30 PM
Matts72's Avatar
Matts72
Alright, I just went to rear disk brakes on my 79 2wd F150. I didn't have the chance to test the stopping distance when I had drum brakes, but they weren't working correctly anyway.
So I tried to be unbiassed in the stopping test, my rear brake pressure is completely adjustable from 20-800 PSI, the manual recommended starting at 50%, I ended up with an acceptable stopping distance and rear brake lockup at about 60% of the metering valves setting.
I found a big empty parking lot and started at one light pole, and hit the skids when I got to a white painted line. That ended up being about 50 MPH, and the stopping distance I paced off at 24 paces, almost 75 feet. I didn't jam the brakes, I tried to stop normally. I imagine that I could try the test again and really just get on the brakes, but I wanted a real world test.
I can tell that the rear disks stop better than the old drums did (they were the factory 1979 drums and shoes, still stamped FoMoCo.
Old Sep 26, 2007 | 01:40 PM
etachell's Avatar
etachell
Same experience when I went to rear discs this summer. I used a similar adjustable proportion valve and I find it is quite handy for adjusting rear brake bias with the truck loaded or empty.
Old Sep 26, 2007 | 03:30 PM
Matts72's Avatar
Matts72
I made a white mark on the body and **** so I could go back to the original setting, and had thought about being able to turn the rear brakes down in the winter, but turning them up whenever I haul a big load will be something to try.
What did you use for a setup?
I'm using GM calipers, re drilled GM 4wd truck front rotors, and custom brackets with Jegs proportioning valve.
Old Sep 26, 2007 | 06:55 PM
Slow's Avatar
Slow
emergency brake? I was going to do this but I need to have an emergency brake here in BC canada. This meant using the eldorado (iirc) brake calipers which made it pretty expensive.
Old Sep 26, 2007 | 07:07 PM
etachell's Avatar
etachell
Let me get some pics posted on the web of my brake system and I'll show you what I did. Probly wasn't the best idea, but it's fun to play with.
Old Sep 26, 2007 | 07:19 PM
m78's Avatar
m78
Instead of readjusting your PPV with every change in loads you might try finding a valve that was on an 88 E350 I had,It had levers from the body cross member to a valve in rear brake line mounted on the axle tube.As it was loaded the levers compressed and turned the valve to allow more pressure to the rear brakes.
Old Sep 26, 2007 | 09:04 PM
etachell's Avatar
etachell
Matt, I did the exact same setup as you. Same proportion valve and everything. I bought mine as a kit that came with loaded calipers, rubber lines, rotors, brackets, and hardware. The price was good and the parts and service is great. Got it from a shop in eBay called Hard On/Off Road.
My F250 had the single piston calipers and light duty front end. I ended up swapping that out for the heavy duty setup off an F350 and got new dual piston calipers. I also upgraded to the 8" dual diaphram vacuum brake booster and the 1 1/4" bore master cylinder. I got rid of the factory proportion valve since it has a front brake delay built in it. Took a bit of work to custom bend all the lines, but the line locks work better than I expected and the system is fabulous now. In the future, I do plan to upgrade to a hydroboost unit for top notch performance.
Here's some pictures of the system. No laughing at my truck.
Rear Disc Setup:
http://i147.photobucket.com/albums/r320/etachell/76%20Ford%20F250/Four%20Wheel%20Disc%20Brakes/FinishedDiscConversion3.jpg
Hydraulic Lines From Master Cylinder to In-Cab Controls Under the Dash:
http://i147.photobucket.com/albums/r...cPlumbing1.jpg
Hydraulic Lines in the Engine Bay:
http://i147.photobucket.com/albums/r320/etachell/76%20Ford%20F250/Four%20Wheel%20Disc%20Brakes/BrakeHydraulicPlumbing2.jpg
Closeup of In-Cab Controls:
http://i147.photobucket.com/albums/r320/etachell/76%20Ford%20F250/Four%20Wheel%20Disc%20Brakes/CabBrakeControlsLabeled.jpg
gotroxs
May 5, 2017 08:28 PM
Mdc9966
Jan 19, 2017 10:13 AM
Ohiofarmboy
Dec 19, 2016 10:53 PM
CT_CREWZR
24
Oct 4, 2009 08:27 AM
MustangGT221
Jul 7, 2003 11:17 AM
