Sponsored by: Real Truck
What makes the speedo work?
Old Sep 25, 2007 | 10:13 PM
nevrenufhp's Avatar
nevrenufhp
I know there's the speed sensor, and the dash gauge, but does it run thru the ECM?
Old Sep 25, 2007 | 10:57 PM
94' 460 F350's Avatar
94' 460 F350
im sure it runs though the computer, because it has to maintain the speed if you have it in cruise control on or maybe another computer controlls the speed, not 100% sure though
Old Sep 26, 2007 | 03:11 AM
Monsta's Avatar
Monsta
Sit. Stay.
Yes, it runs through the ECM. Is something that matter with yours?
Old Sep 26, 2007 | 07:45 AM
RogueSpear2023's Avatar
RogueSpear2023
It goes through computer and it even logs it, I know in the newer vehicles it logs a kinds of info, that can later be used in court, for a or against you if you were in a bad car accident. If you speedometer doesn't work now it's probably your VSS (vehicle speed sensor). It's located on top of your rear differential. There is a line going into form the cab of the truck.
Old Sep 26, 2007 | 07:57 AM
nevrenufhp's Avatar
nevrenufhp
The main thing wrong with mine? it used to be a gasser, now it's going to be an all mechanical IH diesel. The old owner was calling, asking if he could have the ECM. I thought the speedo/cruise got sent thru the ECM.
