Sponsored by: Auxito
Which caps fit
Old Sep 25, 2007 | 12:45 PM
press1's Avatar
press1
Which caps fit
I have a 2001 F150 extended cab long bed. I'm trying to put a truck cap on it and there are limitations about what you can use. For instance, a cap from a regular cab, long bed won't work because of the cab angle. Has anyone been through this and if so, do you know what else fits? Will an older F150 cap fit and not look to bad? I've also heard some older GM long bed caps fit - any experience with that?
Thanks!
Old Sep 25, 2007 | 04:59 PM
KingRanchMan02's Avatar
KingRanchMan02
Hello press1 and welcome to FTE! This question might be better posted in the Misc. section of the forom. There you will find two forums that would better address your question. Aftermarket Products and Appearance and Dress-Up. Good luck!
