Sponsored by: Real Truck
7.3 Engine dies! Need Help
Old Sep 25, 2007 | 08:48 AM
Choppermike's Avatar
Choppermike
Ok, I have a 99 3/4 with 7.3. Lately the engine dies on me going down the road. It usually does it when I am at low speeds or at idle. Sometimes it catches back up and others I have to restart. It has 151,000 miles on it and I service it regular. I just changed the fuel filter thinking I may have had water in the fuel. I even bought diesel at another place and still the same problem. Sometimes the check engine light comes on when it dies and stays on. If I re-start the check engine light goes off. Anyone have any similar problems? I can not Isolate this to electrical or fuel.
Mike
Old Sep 25, 2007 | 09:28 AM
drbalazo's Avatar
drbalazo
I would start with the CPS. Very common on the 7.3 engines. $20 at the dealer and 10 minutes of labor, very easy install.
Old Sep 25, 2007 | 09:33 AM
redford's Avatar
redford
FTE Leadership Emeritus
Here is a link to instructions on how to change the CPS, although the part numbers may be out of date.
https://www.ford-trucks.com/article/...ke_Diesel.html
Old Sep 25, 2007 | 09:35 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Sounds like the CPS is going out. Get the B code one at your ford dealer for about 25.00. Use a 10mm closed end wrench. Takes about 5 mins to change. That is the first place to start. Cheap fix.
If you bring this down to the 7.3 forum and search CPS there is lots of info about this. Very common for it to go out.
BtW you have a 99.5 not 99 3/4.
Old Sep 25, 2007 | 09:36 AM
miller_feed
Darn, I need to type faster. lol
Old Sep 25, 2007 | 09:57 AM
hotroddsl's Avatar
hotroddsl
get 2 cps's keep 1 in the glove box put 1 on the truck & she'll be like new, welcome to the only real 7.3 weak spot I got where I could change them in the dark on the side of the road in less than 15 minutes.
Old Sep 25, 2007 | 10:18 AM
RogueSpear2023's Avatar
RogueSpear2023
I second the CPS notion, I also agree with hotrodds get 2.
Old Sep 25, 2007 | 10:21 AM
redford's Avatar
redford
Got you on a hole shot!
Old Sep 25, 2007 | 10:36 AM
miller_feed
Yep, not just you, drbalazo got me also. lol
Old Sep 25, 2007 | 02:01 PM
kbeefy's Avatar
kbeefy
He probably meant a '99 F250 3/4 ton, not 99+3/4
