Charging Problem!!
Old Sep 25, 2007 | 12:41 PM
bobj49f2's Avatar
bobj49f2
No, I haven't gotten the wheels on yet. I've been trying to get it running. I got the brakes working, finished rewiring, had cooling problems and had to rebuild the radiator and now my charging system isn't working, kind of like your current problem. I have the wheels in my shop and I what to paint the rims black so they look good on my maroon panel. Next year if I can get everything working correctly this year, I'm going to paint the panel red.
Old Sep 28, 2007 | 01:11 AM
Ole' Green's Avatar
Ole' Green
Those stock generators were rated at 25 amps at 12 volts. You likely dont have more than that connected. I'm all in favor of a 3-wire/1-wire alternator, but a properly working stock generator will do the job. Have a shop check the generator/regulator and make sure you have good grounds and good clean wiring connections.
Good Luck.
