'71 390 miss
Old Apr 8, 2002 | 10:59 PM
bigoldblue's Avatar
bigoldblue
Post '71 390 miss
Hey all
I've got a miss on my 71 f100 390 4bbl, that I cannot locate a reason for. Little miss at idle not real rough, same miss all the way thru the rpm range. Does not miss while cruising though. Also I've got to pump and pump and pump to get it started in the morning(probably due to no choke) but once it does start it backfires for about the first 30 seconds then runs better. I've changed cap rotor wires plugs, switch to pertronix ignitor, coil, fuel filter air filter, checked timing, checked vaccum, and still nothing. Just seems to be getting a little worse. any ideas?
thanks
david
Old Apr 9, 2002 | 12:36 AM
BB's Avatar
BB
'71 390 miss
Do a compression check, you might have a burnt exhaust valve.
Barry
Old Apr 9, 2002 | 03:10 PM
bigoldblue's Avatar
bigoldblue
Post '71 390 miss
well, it started getting worse today, so i went out a got a new vaccum gauge, turns out the old one was junk. vaccum is jumping between 9-15 very rapidly. I sprayed everything with carb cleaner looking for vaccum leak couldn't find anything. sound like a burnt valve?
thanks for the help
david
Old Apr 10, 2002 | 11:16 AM
dvlinnell's Avatar
dvlinnell
'71 390 miss
What kind of card are you running?
Old Apr 10, 2002 | 11:23 AM
bigoldblue's Avatar
bigoldblue
'71 390 miss
carter afb 625 cfm 4bbl
Old Apr 10, 2002 | 11:38 AM
CmprSpecial's Avatar
CmprSpecial
'71 390 miss
weldworks54
Sep 11, 2011 09:45 AM
dongreene
21
Jul 6, 2006 10:45 PM
doncarter
Feb 10, 2005 02:27 PM
eightysix
Modular V8 (4.6L, 5.4L)
Aug 9, 2004 04:53 PM
rick123
Feb 14, 2000 09:08 PM
