289?
Old Sep 24, 2007 | 01:37 PM
Kustomfiend's Avatar
Kustomfiend
Question 289?
After weeks of blood, sweat and tears, I managed to do a successful swap, from 300 to 302...or so I was told. It was only when I had to check for VIN numbers that I discovered the casting number: C4OE-6015-C, which would reveal that the engine was produced in 1964 and came out of a Fairlane and is a 289. Aaaaaaargh!!!!!
What done is done, so that 460, in friend of mines shed is starting to look at me weird.
So, I have a couple of questions, being add odds with conflicting advice form "experts".
Starter: As I bought the engine without a starter, I fitted the original 300 starter and it works, but is there a specific starter matched to the 289?
Tappet noise: This is an enigma, as, yet again, there is conflicting opinions. How do I set the rocker arms, et cetera? As the valvetrain is somewhat noisy...sounds more like a Volkswagen. After hearing a 351 in a '54 F-100, I am determined to silence the 289.
Damper: Is there a difference between the 3-bolt and the 4-bolt? Apparently, the Fairlane 289 came out with a 3-bolt, but my 289 is a 4-bolt.
On the intake manifold, behind the carburator, there appears to be a cover-plate with three bolts. What is this?
Any tips on setting the 2100 carb? Running a bit rich, and turning the mixture screws out all the way provides no results. Disconnected the choke, rebuilt the carb...still nothing.
Old Sep 24, 2007 | 02:20 PM
Mil1ion's Avatar
Mil1ion
That is only a design number.
The actual casting date is also on the parts which is more important.
ie: * 8C18 *
Also I noticed you are new.
Please ask the specific topics in the specific related forums.
ie: Engine forums for engines
Fuel delivery for carb questions
see post #1
https://www.ford-trucks.com/forums/1...ease-read.html
etc.
No 289's were put in 73-79 trucks and this forum is for specific 73-79 truck topics.
Topics:
Starter.. yes it goes by application (M/T or A/T) although service starters can be the same for multi-year engines
Got a pic of the cover plate ?
Old Sep 22, 2008 | 08:50 PM
61eline's Avatar
61eline
cover plate
if i remember correctly the cover plate with three bolts is where the original throttle linkage brackets attatched
Old Sep 22, 2008 | 10:14 PM
fastfarmer's Avatar
fastfarmer
Mid 1965 were the first 289s with the modern 6 bolt bellhousing. Untill then 221-260-289 used a 5 bolt bellhousing. If your engine bolted up to the 300I6 bellhousing then it is not a 64 289.
Old Sep 24, 2008 | 07:10 AM
Kustomfiend
Useless information?
In reponse to Mil1ion...I would like to politely inform you that I have made the above posts, for exactly the reason that my truck is, in fact, a 1973 Ford F-100 Custom! Do you really underestimate my intelligence? Common sense would negate that I would like to acquire advice and tips from gentlemen, like yourself, that also owns a vehicle of the same design and type.
On further investigation, it would appear that all the above questions pointed to one common denominator: two tappets had collapsed and the motor was running on six cylinders. The carburator was certainly not faulty and the motor is indeed a 302 hi-performance motor...merely a block bored to 302 size.
Once the collapsed tappets had been replaced...along with all the other tappets (I thought I'd mention that, as a matter of IQ and common sense) my 1973 Ford F-100 Custom took off like a rocket, with squelling tyres and a roar mightier than a lion.
Old Sep 24, 2008 | 07:34 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Look at the date on the post...that member is gone.
Old Sep 24, 2008 | 07:59 AM
4x4 Bart's Avatar
4x4 Bart
Thanks , Kustomfiend for the update, as far as I am concerned your comments and questions are always welcome on the best forum on the net.(73-79s) Hope to here from you in the future......... Bart
