a 428 crank
Old Apr 13, 2002 | 09:30 PM
ruthless's Avatar
ruthless
a 428 crank
I am ready. I have all parts except for the new cam and lifters that have not arrived from Summit yet. (been two weeks).Where can I get a 428 crank for this 390 re-build?
Old Apr 13, 2002 | 10:36 PM
big block power's Avatar
big block power
a 428 crank
same place you would get a 390 crank, both engines are
from the same "family". Basically any auto parts store.
Fe power
Old Apr 14, 2002 | 01:33 PM
karlsd's Avatar
karlsd
a 428 crank
Keep in mind that if you put in a 428 crank, you'll need a 428 flexplate/flywheel, too. The 428 is externally balanced via a weight on the flexplate/flywheel.
Old Apr 14, 2002 | 07:15 PM
ruthless's Avatar
ruthless
a 428 crank
Yes, thanks the flywheel and balancer too. You must have better auto parts stores than I do. Can you suggest the name of an auto parts store that would have the crank?
Old Apr 14, 2002 | 11:29 PM
karlsd's Avatar
karlsd
a 428 crank
You don't need a new harmonic balancer. Only the SCJ 428 had a counterweighted balancer. All other FE engines, including the 410, 428, and 428CJ, use the same harmonic balancer.
428 crankshafts are not typically available from your neighborhood Pep Boys or AutoZone. Any good machine shop will know where to get one, though. You're going to need a machine shop, anyway, so find one now that knows FEs. If they're any good, they'll probably have a few 428 cranks in the shop that they'd sell you. If not, they'll be able to get one.
Old Apr 15, 2002 | 07:34 PM
Scouder's Avatar
Scouder
a 428 crank
Start with carlsfordparts.com. He will have 428 cranks.
-Scouder
Old Apr 15, 2002 | 09:51 PM
ford_boy4819's Avatar
ford_boy4819
a 428 crank
