Alternator help
Old Sep 24, 2007 | 08:40 AM
mark_a's Avatar
mark_a
Alternator help
My generator went bad and I went to the parts store and got a new alternator for the truck. Obviously it is a far different shape and will not bolt in. Is there any readily available adapters or will I have to take another route and go the salvage yards to find an original?
Thanks for any help
Old Sep 24, 2007 | 08:54 AM
cobraguy's Avatar
cobraguy
Mark welcome, your going to have to do some adapting. What engine are you working on. It shouldn't be too bad. Rich.
Old Sep 24, 2007 | 08:58 AM
mark_a's Avatar
mark_a
I'm sorry for not mentioning the engine, it is a 223
Old Sep 24, 2007 | 11:00 AM
cobraguy's Avatar
cobraguy
OK Mark is the pivot (bottom) mount on the alternator shorter than the one on the generator. They usually are. Better to remove the generator and do a side by side comparison. If this is the case you need to add a spacer or stack washers to make up the space. As far as wiring goes you'll need a regulator that is used for alternators wich is different from the one used for generators. Then follow this link www.mustangsteve.com/GENtoALT.html its for mustangs but it will be the same for your truck. Wires may be colored different.
jcd
Mar 24, 2016 02:36 PM
Camper Special Gene
Jan 29, 2015 07:50 PM
coalnation
Large Truck
Aug 31, 2014 10:02 PM
switchback
Electrical Systems/Wiring
Dec 1, 2003 10:11 PM
Andysutt
Oct 14, 2003 02:43 PM
