no low beams?
Old Sep 23, 2007 | 11:41 PM
crack's Avatar
crack
no low beams?
for some reason lastnight when I fired up my truck went to flick the lights on and only my markers came on...my high beams work....whats the deal? dimmer switch?
Old Sep 24, 2007 | 04:54 AM
wbhinton's Avatar
wbhinton
Could be a bad wiring harness. I know I need to replace mine.... my DS (driverside) lowbeams stay incredibly dim
Old Sep 24, 2007 | 06:39 AM
totin_tools's Avatar
totin_tools
What about the turn signal switch. Does it allow the highs to stay on when you pull and push on it? I once had a Taurus and the switch went out thats why I am saying it.
Old Sep 24, 2007 | 06:47 AM
Izzy351's Avatar
Izzy351
Check your fuses -- there is one fuse per low-beam (2-10A) and an overall fuse for the highbeams and lowbeams (1-30A). I believe those values are correct -- may be off a size, but you get the idea...
Joe
