ABS Brakes
Old Sep 23, 2007 | 09:08 PM
Brian0445's Avatar
Brian0445
ABS Brakes
At or below 5-7 mph my abs brakes come on and the pedal gets soft utill i come to a stop. I checked the fluid level on the master cylinder and its fine.... what should i check next the front or rear sensors? Thanks for any input
Old Sep 23, 2007 | 10:05 PM
mech2161's Avatar
mech2161
Check the front wheel bearings if your truck has 4wheel abs.
Old Sep 24, 2007 | 12:59 AM
matty169's Avatar
matty169
G.M.s do this all the time. Remove front wheel speed sensors and clean the mating surface of the sensor, without getting crap in the hole for the sensor. If you have a bunch of metal on the magnet when you remove the sensor it is time for wheel bearings. Good Luck. Also, clean off the magnet.
