Bronco II Ford Bronco II
This is getting old...
Old Sep 23, 2007 | 05:50 PM
DodgeBoy97's Avatar
DodgeBoy97
I have a 1986 bii 2.9L v6 4x4 and it keeps stalling on me (its an auto) like when i come to stop it will drop very low like 400 or so on the rpms and go back up to like 1200 or keep going down and stall i have replaced the TPS MAP AICV but it will still do it it used to surge but sense i got the new TPS it doesnt but it only has this problem when the truck is hooked up to the map sensor but it runs real smooth and clean but when i un hook the map it runs real ruff but it wont die at all but it smokes its weird any ideas comments anything i am open to all ive been trying to trouble shoot this for the last month or so ive replaced the plugs wires distributor a whole tune up and replaced what ive heard that will cause it so any ideas i would love to hear thank you.
Old Sep 23, 2007 | 06:38 PM
fl1a's Avatar
fl1a
That surging and stalling sounds like the TFI module on the side of the distributor. It
is not a monitored module as far as having fail codes. Many times when one fails the
surging happens when the engine gets to operating temperature. There is a test for
it in the read first section of this thread. These bugs are maddening, but once you
get them chased down, these are pretty good engines.
Old Sep 25, 2007 | 05:47 AM
DodgeBoy97's Avatar
DodgeBoy97
oh alright, i guess ill give that a shot thanks.
Old Sep 29, 2007 | 12:28 AM
Red460's Avatar
Red460
Talking
My dad's 84 Mercury Grand Marquis use to do that he would ride the gas and the brake to keep from stalling a little risky. Especially with a carb. Good luck with your B2.
Red460
Old Oct 15, 2007 | 08:55 PM
DodgeBoy97's Avatar
DodgeBoy97
I went to Orielly's and i asked for the TFI module but they couldnt find it or tell me what it was so if someone could post a picture of it and the full name what it does etc that would be great thanks.
Old Oct 15, 2007 | 09:58 PM
mrshorty's Avatar
mrshorty
Try calling it an ignition control module (ICM).
Old Oct 16, 2007 | 10:03 AM
fl1a's Avatar
fl1a
You might also want to shop around a little, you may find a better price than O'reilly.
Old Oct 16, 2007 | 01:50 PM
tbolt 460's Avatar
tbolt 460
find a 89 computer and try it. worked for me
Old Oct 16, 2007 | 03:45 PM
rebocardo's Avatar
rebocardo
This sounds like a dirty IAC to me. Details about cleaning it are in the Ranger forum. The IAC flicks on and off many times a minute to adjust idle. A defective one will have have a wide range of RPMs to the point of stalling.
A bad TFI on the other hand, will not have the idle bump up to 1200 rpms all by itself. It will just drop the RPMs and die, it will not increase beyond idle RPMs.
Disconnecting the MAP sensor will kill the vehicle, probably because loss of vacuum usually means WOT to the computer. I haven't thought too much about why though, just a guess.
Old Oct 16, 2007 | 07:06 PM
fl1a's Avatar
fl1a
When the TFI is failing, it can go through a period when it will lose output to the coil.
The engine will begin to die, then the TFI functions again. Then the idle corrects. It
can rev up over 1k. I have had 2 TFI modules show this symptom, and with an
automatic transmission, it can be a nightmare in heavy traffic.
Old Oct 16, 2007 | 09:49 PM
DodgeBoy97's Avatar
DodgeBoy97
alright thanks alot.
f1001969mike
1978 - 1996 Big Bronco
Nov 11, 2012 05:10 PM
Lead Head
26
Nov 7, 2012 12:59 PM
Super Dave
13
Jan 8, 2008 07:58 AM
grndlzrd
Jan 7, 2007 06:15 PM
88bii
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 25, 2004 12:07 AM
