front brake leak
Old Sep 23, 2007 | 05:44 PM
cbjr61's Avatar
cbjr61
front brake leak
is it ok to pinch off the brake line till i get it home so i can fix it . will i still have some front brakes on other side or just back brakes is it safe to do this
thanks
Old Sep 23, 2007 | 08:06 PM
quicklook2's Avatar
quicklook2
not really the safest thing to do, but in an emergency it should work.
use the emergency brake if you can and time lights and watch out for the unexpected.
Old Sep 23, 2007 | 08:12 PM
netscaner's Avatar
netscaner
Unless you can find a non rusted section that can be flattened then folded over you probably won't be able to hold much pressure. But a vice grip holding the end of a line can be fairly effective.
Old Sep 23, 2007 | 09:32 PM
quicklook2's Avatar
quicklook2
that is what i thought he would try to use, i should have asked.
Old Sep 24, 2007 | 03:48 AM
kcb37's Avatar
kcb37
Vise grips work well on air brakes.
