Low Oil Pressure?
Old Sep 23, 2007 | 05:15 AM
ctvanover's Avatar
ctvanover
Low Oil Pressure?
I bought an '84 302 from a '84 Mustang GT a friend of mine had and set it in a '85 Ford F-150 4x4. He started it up and I heard it run before I bought it. The oil pressure was up about 3/4 on the pressure gauge. To make a long story short, after about a month or so it wouldn't start one day. The shaft on the oil pump had stripped but we didn't know about until after we tore it down and found it. So I decided to go ahead and overhaul it from the ground up. Everything was new on the inside. After the rebuild everything was running fine except for about 6 to 8 months later I've noticed the oil pressure is down around the 1/4 to low mark after it warms up. It still had a high pressure reading even after the rebuild but I've got sneaky feeling something aint right and I don't want to ruin a good strong motor like this one. Anybody got any ideas?
Old Sep 23, 2007 | 05:36 AM
rkymtnman30's Avatar
rkymtnman30
when you drained the oil was there any junk in it? Could be a clogged pick up. I had a 5.0 do that not long afert rebiuld it was some gunk clogging the sending unit you may want to look there.
Old Sep 23, 2007 | 05:49 AM
ctvanover's Avatar
ctvanover
OK! I'll look there and see.
Thanks!
Old Sep 23, 2007 | 05:56 AM
rkymtnman30
no worries mine had a little piece of RTV blocking part of the sending units hole.
Old Sep 23, 2007 | 03:11 PM
Piffery1's Avatar
Piffery1
Get a good mechanical oil pressure gauge and see what the actual pressure is. Don't get a gauge with plastic tubing; the better ones use copper tubing.
EricdeToad
Feb 24, 2015 09:27 PM
funkyfullwidth
Aug 18, 2011 05:31 AM
HardWorkinMan
Mar 30, 2010 07:24 PM
black58
Jul 12, 2005 05:51 AM
Hawkdriver
Oct 5, 2003 06:48 PM
