Digital ODOMETER readout
Old Sep 23, 2007 | 03:49 AM
john.r.mcclain's Avatar
john.r.mcclain
Exclamation Digital ODOMETER readout
Hopefully someone knows what to do here. My odometer readout isn't there anymore!! The backlight on the instrument panel works. Just no readout of odometer/temperature. I checked several fuses in the fuse box and saw nothing wrong. So how do I get my odometer back? This is the first time I've had a problem with my 04 FX4. Everything else is working great.
Old Sep 23, 2007 | 09:20 PM
VFR_Man's Avatar
VFR_Man
A friend's '05 had the bulb for the LED burn out just recently. His was some goofy, little, christmas-tree-light-looking bulb (not the regular 194) that took the dealer a couple of tries to order correctly. Maybe yours has the same bulb burnt.
Old Sep 24, 2007 | 01:04 PM
Quack Addict's Avatar
Quack Addict
I had something similar. I lost my lights in the odometer area at night in my '06 SCREW. I took it to the dealer and they said the whole instrument cluster had to be replaced. The dealer also has to give the mileage to the parts supplier so it can be pre-programmed. Once it is installed there is no changing it.
I hope this helps.
Mike Aka Quack Addict
'06 SCREW FX4
Old Sep 25, 2007 | 08:32 AM
FS-150's Avatar
FS-150
Does he have the XLT style odometer, outside temp., compass, low fuel display? The backlit portion of the diplay quit working on mine. The LCD (black) works, it just cannot be seen at night. I was hoping I could just change the bulb. If I have to change the cluster, I will skip it because it is out of warranty.
Old Sep 25, 2007 | 08:45 AM
VFR_Man's Avatar
VFR_Man
I think you're right. He has an STX, so I think it is an LCD with a backlight like you said so it's just not visible at night.
I'm not sure if he ever did get the right bulb yet. The parts catalog the dealers have must not make it very obvious what bulb it is or Ford changed the thing mid-stream or something.
Old Sep 25, 2007 | 08:49 AM
FS-150's Avatar
FS-150
Thanks for the info. I will check into it and report back.
Old Sep 30, 2007 | 06:27 PM
dmabston's Avatar
dmabston
I had the same problem and item was the light cluster. I was replaced under warranty. Out of your pocket will be around $400.00
Old Sep 30, 2007 | 10:49 PM
benningstspeed1.0's Avatar
benningstspeed1.0
you will have to replace the whole cluster. that generally has to be done at a dealer as most shops are not equiped to down & up load the cluster info
