Bellhousing question
Old Sep 22, 2007 | 05:38 PM
Bullride_101's Avatar
Bullride_101
I have an NP-435 with a carbed 300. The bellhousing has a significant crack (probably 2.5-3 inches) in it and I am planning on pulling the engine to do some repairs and am wondering if it would just be easier to go to a scrap yard and get another one or if I should have it welded up?
Old Sep 22, 2007 | 10:58 PM
lasthighboy's Avatar
lasthighboy
if you can find a good one in a junk yard i'd probably go that route. it's a cast iron bell housing and cast is hard to weld. ud probably have to take it to a welding shop and could cost as much as a junkyard one anyway
Old Sep 25, 2007 | 11:57 AM
rsalter66's Avatar
rsalter66
I've welded cast many times with my small mig, the trick is to heat it up before you weld it, but its still a crap shoot, depends on how good you are, if you have never messed with it I would just buy another, I did it just to see if I could do or not
Old Oct 11, 2007 | 10:49 PM
tomcasino's Avatar
tomcasino
If you can find another one that's great. Go that route. Otherwise be sure to use nickel rod to weld cast iron.
