lifter question
Old Apr 30, 2002 | 11:07 PM
big block power's Avatar
big block power
lifter question
I have a 1970 250cs w/np435,,dana60,4.10,,390 2bbl,
the lifters on one side tap cause I think some valve cover gasket
glue slid down in there and hardened,because i remember
putting more on that side cause it was dumping oil,and
thats the side that taps.is there stuff that eats up
gasket glue that could be dumped in or is this a different
problem?how long do lifters last after they start tapping?
One more here.... I had third gear opened up to 60 miles
an hour w/np435 and 4.10s,31"wheels, what rpm would I
be pulling?
Fe power
Old May 1, 2002 | 02:11 AM
BB's Avatar
BB
lifter question
On the rpm thing, assuming the speedo is correct you would have been taching 4,430 rpm. This is what cranked out of the online rpm calculators using 1.66:1 as your final gear ratio in third and 31" diameter tires.
Barry
[link:www.ford-trucks.com/guidelines.html | FTE Moderator]
Old May 1, 2002 | 06:42 PM
big block power
lifter question
4400 seems about right,thanks,how long do the
and when i bust the top open what could I
do to get it to rev to 5000 or so?, its
got C8AE-H heads w/ orange springs,whats
with orange colored springs?any info is
greatly appreciated
Fe power
Old May 1, 2002 | 10:24 PM
karlsd's Avatar
karlsd
lifter question
