Help!!
Old Sep 22, 2007 | 03:40 PM
jjpic's Avatar
jjpic
Help!!
2003 EB - Did a brake job this morning and while I was doing it I had the radio on. Strangely enough when I started it up the gauges went haywire. I did'nt think anything of it, then I went for a test drive and the driver's power seat and the power mirrors don't work and it seems like the car is not charging.
The fuses for the seat and mirror are fine.
When I hook a trickle charger up to it, after about five minutes the charger trips out like its overloaded. I would assume the battery is bad but what could be up with the seat and mirrors?
Any help would be appreciated.
Old Sep 23, 2007 | 12:36 AM
jjpic's Avatar
jjpic
I know it's a wierd problem thats hard to diagnose over a computer, but does anyone have a clue on what it could be?
Old Sep 23, 2007 | 10:58 AM
jjpic's Avatar
jjpic
Changed the battery, truck starts, I still am not sure if its charging right and the seat and mirrors are still dead. There is power at the fuses.
Very confused, hope someone can help.
Old Sep 23, 2007 | 11:23 AM
projectSHO89's Avatar
projectSHO89
Test the charging system to see if it's active. Just measure the battery voltage with a meter to see if you have 13.8 - 14.4 V or so at idle speed.
Do you have the memory seats/mirrors? If so, check fuse F4 in the under dash fuse panel.
Steve
Old Sep 23, 2007 | 11:53 AM
jjpic's Avatar
jjpic
Is there a another fuse panel other than the one behind the passenger side kick plate?
I'm only getting 12V at the battery at idle.
Old Sep 24, 2007 | 07:24 PM
jjpic's Avatar
jjpic
I knew it was charging, but since the seat/mirrors weren't working, I thought maybe something else was wrong. Well I dropped it off at Ford, they said I needed a new Alternator, the Alternator harness, and the drivers seat module (Computer that controls the memory settings for the seat, the pedals, and the mirrors)
$ 1,400 later (OUCH) I should be back on the road.
Just thought I would update everyone, just in case it happens to someone else.
I'm thinking maybe the alternator problem may have caused a surge that fried the module.
Old Sep 24, 2007 | 08:44 PM
waboose's Avatar
waboose
I just read your post, I would try changing the alternator only, when mine went all the gauges went as you explaine "haywire". I doubt you need to change your harness if you have 2003, haven't changed mine yet and its a 97.
Old Sep 24, 2007 | 10:52 PM
dkcpacific's Avatar
dkcpacific
dkcpacific
My 98 Exp. went to Sears and they did the alternator for about $385. I would also change the alternator first and see if the other problems are cured.
makenzie71
Feb 17, 2015 01:51 PM
Forty9ford
Oct 2, 2014 05:43 PM
ozark1
36
Dec 14, 2012 08:01 AM
