Light harness for towing
Old Sep 21, 2007 | 11:52 AM
frankenherder's Avatar
frankenherder
I have purchased the FORD light harness for my 2001 Explorer. My SUV did not come with the tow package.
I just bought a new trailer, all the lights work except the running lights. I had this issue with my boat trailer too.
Is this common with the 4 flat trailer wiring? I heard you may need a convertor or something?
Thanks
Matt
Old Sep 21, 2007 | 02:43 PM
Bear River's Avatar
Bear River
Former ******
Just wire the thing for 6 or 7 pin connectors. If you have 7 pin trailer wiring, you can adapt to any other electrical hookup, and everything works as it should. But with 4 pin, you are stuck with right blinkers, left blinker, running lights, and ground. 7 pin is so much better.
Old Sep 21, 2007 | 03:03 PM
bdmcdonald's Avatar
bdmcdonald
Make sure you have the ground connected on both sides. Very important. here is a simple diagram how to do the wiring...
http://www.rverscorner.com/wiring/4pole.html
Old Sep 23, 2007 | 08:26 AM
frankenherder
The wire is 4 flat. I called the trailer manufactorer and they seem to think that is an issue with the Brown wire from my truck. I looked at the connection and there is some corrosion in there. i will attempt to clean it or just purchase a new end for it and take better care of it.
Thanks for the input, i will keep you posted.
Matt
DieselVol
May 15, 2013 11:22 PM
drumfield
Electrical Systems/Wiring
Sep 3, 2011 07:44 PM
Matt_camperscorner
Jan 15, 2008 07:01 PM
gvandyke
Oct 18, 2007 12:25 AM
rallyXR
All Things Towing
Dec 26, 2003 11:56 PM
