testing glow plugs and i need help with my intake?
does anyone know how to test a glow plug with a "timeing light"? i guess it has been done but i do not know how... and can anyone shed some light on how to open up my intake?
Timing light with glow plugs? Wouldn't you have to have a much more sensitive inductive pickup on the timing light to get it to fire the light from a glow plug voltage?
I've never heard of it, but I suppose it could be done.
from what i hear you hook the positive end of the timing light to the glowplug and negitive to the positive of the battery all i kno is i need more opinion before i do so
Uhh...no.
You use a test light, not a timing light. All you do is connect one end of the light to the battery (+) and the other to the glow plug (-), what you are doing, is grounding (-) the light through the glow plug.
This assumes the glow plug is installed in the engine, but you also have to disconnect the glow plug from the engine wiring harness, or the light can ground through the harness and give you a false reading.
david85 is correct you use a TEST light NOT timing light!
as for opening up the intake all you can do is build a ram air type system
i built one and put in 3.5 inch exhaust the exhaust system gave me the most noticeable power.
