Sponsored by: Real Truck
lift question
Old Sep 20, 2007 | 04:30 PM
britton02f250's Avatar
britton02f250
lift question
i put a 6 inch pro comp lift on my 2002 f250 psd do i have to use the new sway bar links or is that just on the older models. thanks
Old Sep 20, 2007 | 07:33 PM
DCSpecial's Avatar
DCSpecial
You should use the sway bar links.
Otherwise the stock links will pull your sway bar up.
Old Sep 20, 2007 | 07:39 PM
BobbyDiesel71's Avatar
BobbyDiesel71
Are you happy with this ProComp lift kit?
How does it ride?
would you post some pics of the lift?
Old Sep 20, 2007 | 08:02 PM
britton02f250
yea it did pull them up but i thought that the direction said to only use the new links on 99.5 and under maybe i was reading them wrong does anyone know where i can get the instructions online on how to install a procomp lift i am taking it to a 4x4 shop saturday to have it all looked over i am not that trusting of the work i did installing the lift on my truck think i bit off more than i could chew took me 3.5 days to install lift little longer than the dir. said
Old Sep 20, 2007 | 08:04 PM
DCSpecial's Avatar
DCSpecial
Pro Comp's site have instructions online?
Old Sep 20, 2007 | 09:21 PM
britton02f250
found instructions only 1999 models use the new links that eases my mind a little but after reading instructions may have not done a few things right better go ahead and have it checked by the pros and dont mean 4wheelparts if you want to hear my story on that message me its kind of long but interesting and just enough to **** anyone off.
Old Sep 20, 2007 | 09:27 PM
bbender85's Avatar
bbender85
i took my swaybar out. way better.
Old Sep 20, 2007 | 10:00 PM
77hiboyboy's Avatar
77hiboyboy
I'm in the process of a 6-inch that I bought used. Nobody has any information on any lifts it seems like. I have part #'s that nobody can recognize, and 6 gold anodized srips that are in pairs, in 3 different thicknessess that nobody knows what they are.
Old Sep 20, 2007 | 11:32 PM
kbeefy's Avatar
kbeefy
I think they changed the end link design in '00. For a 6" lift you should have extended end links
Old Sep 20, 2007 | 11:33 PM
kbeefy's Avatar
kbeefy
any more info> pics?
Old Sep 21, 2007 | 12:01 AM
Gordondavis's Avatar
Gordondavis
77hiboyboy, the plates you are talking about are spacers. They are supplied with the kit if your truck has a center drive shaft bearing, I hope you measured your trucks height prior to the disassembly. For my truck an F350 it requires 1/4" of shim for each inch of rear lift. Rember that a 6" lift may not give you a true 6" it can be more or less depending on the kit. Good Luck
Old Sep 21, 2007 | 12:43 AM
77hiboyboy's Avatar
77hiboyboy
I have a regular cab, no carrier bearing. No wonder I couldn't find anything that even came close to resembling where that went to. I didn't measure, just pulled my old lift off and if I can come close to being level and align I will be happy. My old slip-yoke on the rear is loose and I figured if I needed driveline modification now would be the time to do it. I probably should have measure because its looking more like an 8 inch as I go. I was foolish for buying a used lift, but the story changed after I bought it. Turns out instead of him upgrading for the 8 inch lift after he bought it, this 6 inch came with the pickup. I think I did alright on the price and have some room to work with. Pickup had a leveling kit and 305's on it. This is right after getting the front springs bolted up and dropped back to earth.
Old Sep 21, 2007 | 08:59 AM
britton02f250
well im taking mine in for an inspection by a 4 wheel drive shop here ill let yall know what they say about the sway bar links tomorrow.any other ?'s yall want me to ask while im there let me know britton.wood@yahoo.com
Old Sep 21, 2007 | 11:39 AM
2000silverbullet's Avatar
2000silverbullet
Amen bender. With a (in my opinion) crappy stiff Pro Comp lift, my need for sway bars disappeared quickly. I pulled both of mine off, rides a little better but still keeps you puckered when you hit a bump in the road....
Old Sep 21, 2007 | 11:48 AM
britton02f250
my truck is a diesel does that matter on removing my sway bar also what does it effect taking it off. thanks
