MAF vs. Speed Density
Old Sep 20, 2007 | 03:20 PM
Carson1219's Avatar
Carson1219
Question MAF vs. Speed Density
I have read all these things on this website about Mass air flow and speed density, what is the difference between the two? I have a 1992 F-250 4x4 with a 351, which do i have MAF or Speed Density?
Old Sep 20, 2007 | 04:29 PM
EPNCSU2006's Avatar
EPNCSU2006
Your truck has speed density. What this means is that the amount of fuel injected is determined primarily from a combination of engine rpm (speed) and manifold pressure (air density). Mass air flow determines the proper amount of fuel based on engine rpm and the actual mass flow of air entering the engine, as determined by a mass air meter.
Old Sep 20, 2007 | 07:07 PM
Carson1219's Avatar
Carson1219
Thank you very much
Old Sep 21, 2007 | 03:24 PM
BACKIEL's Avatar
BACKIEL
The other big difference in how they work is speed density batch fires fuel injectors whereas mass air fires each injector seperatly.
Old Sep 21, 2007 | 09:45 PM
pcmenten's Avatar
pcmenten
My 86 Mustang 5.0 is a Speed Density SEFI engine. No, SD does not mean it's batch fire.
A Mass Air meter is a hot wire. The electrical resistance of the wire varies with the temperature of the wire. As air passes over the wire, the air cools the wire and changes its resistance. More air cools the wire more.
Old Sep 22, 2007 | 01:26 PM
EPNCSU2006's Avatar
EPNCSU2006
Paul's right. While these trucks are batch fired on the speed density versions, the injection method is independent of whether the fueling is speed density or mass air based. One could program a computer to use mass air and batch fire the injectors if that was desired.
robertbourque
Jan 18, 2007 05:58 AM
kkieon
Sep 24, 2006 08:03 PM
minnesotamadman
Sep 11, 2005 09:06 PM
MORTORQUE
1978 - 1996 Big Bronco
Aug 14, 2004 10:29 PM
broncobilly72
Jan 19, 2004 10:10 PM
