ele. choke always hot
Old Sep 20, 2007 | 02:49 PM
montanamuddnmtns's Avatar
montanamuddnmtns
Question ele. choke always hot
I have a 85 f250 with new 460 w/ edelbrock. I found a dead battery after a few days not using the truck. Then noticed choke not working during cold start. I checked the choke this morning with key off and it was hot, quite hot. I let it cool then changed the power source and it heated up. Has anyone ran into something like this or is there anyone out there that can help? Thanks
Old Sep 20, 2007 | 04:36 PM
Franklin2's Avatar
Franklin2
It should be on a key-on source. Get a testlight or meter, and you should not have voltage at the choke unless the key is in the run position.
Old Sep 21, 2007 | 12:18 AM
montanamuddnmtns
Thanks Dave. Choke has volt. with key in off postition. power source runs off the alt. I chased the wire and it seems fine. I suspect the alt. maybe a short. Any other ideas?
Old Sep 21, 2007 | 01:23 AM
big hoss 29's Avatar
big hoss 29
I've got the same carb and I ran a wire from a key-on tab on my fuse block.
1930 Dodge
89
Jan 8, 2013 12:33 PM
Rusty_S
Dec 12, 2012 02:24 PM
sfc11b
May 7, 2005 02:29 AM
HawgDawg
Mar 16, 2005 09:17 PM
78bronco
Apr 16, 2002 07:26 AM
