What does a header leak sound like?
Old May 18, 2002 | 09:39 PM
proeliator's Avatar
proeliator
Old May 20, 2002 | 06:42 PM
fordtruckin's Avatar
fordtruckin
Like I said in the subject, what does a headers leak sound like? Because there is, as Ross Perot would say, a giant sucking sound coming from the 428. On that note, what are some good header gaskets for the FE?
Old May 20, 2002 | 08:30 PM
Ratsmoker's Avatar
Ratsmoker
A header leak sounds lke you have a popping sound under the hood. I think it is the felpro number 1442 that port match to my edel heads perfectly. I dunno how they will match to yours.
Old May 20, 2002 | 09:09 PM
Like M. Fords's Avatar
Like M. Fords
Running an engine without an air cleaner will produce a sucking sound, as would having a broken vacuum line. A header with a leak somewhere between engine and collector will produce more of a ticking sound. Sounds sorta like a yard sprinkler.
Old May 20, 2002 | 09:38 PM
Ratsmoker's Avatar
Ratsmoker
That is a little better description.
Old May 21, 2002 | 12:55 AM
fordtruckin
False alarm guys, it was - get this - the brake vacum, which had never gotten a plug since we put the new carb on! I'm embarrassed but at least it runs right now. Thanks for the help though!!
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
