Sponsored by: Real Truck
Skyjacker 6" kit opinions
Old Sep 20, 2007 | 10:36 AM
jopiel's Avatar
jopiel
I am about to order a Skyjacker 6" kit with rear blocks and Skyjacker Nitro shocks for my 02 F250. Do any of you run this kit, and what are your opinions? I don't want to spend the $$$$ on a DR or coilover kit.
Thanks
Old Sep 20, 2007 | 11:43 AM
jomac11's Avatar
jomac11
If you tow at all, you will want to re-think those blocks. I dont know if its an option, but a full 6" spring would really be a better and safer bet.
Old Sep 20, 2007 | 12:45 PM
BadDogPSD's Avatar
BadDogPSD
Skyjacker makes a good product. I agree on using lift springs vs. blocks.
Old Sep 20, 2007 | 05:09 PM
Beerstalker's Avatar
Beerstalker
A 6" lift usually only lifts the rear 2-3" compared to a stock F350. As long as it is a one piece block it shouldn't be that big of a deal. For 8" and up you should definitely not use a block though.
Old Sep 20, 2007 | 09:28 PM
lowet's Avatar
lowet
the pitman arm is a additional part, you can get the rear springs later or run ladder bars if you like, I ran limit straps on mine to keep the front driveshaft from being over extended, I also used the extended s/s brake lines, I also got the rear springs later to stop the axle hop.
Old Sep 20, 2007 | 11:39 PM
kbeefy's Avatar
kbeefy
well, if your keeping your truck for a while you will DEFFINATLY appreciate the $$ spent on springs.
If you just drive your truck ocasionaly and don't care if it ruptures your kidneys when you drive it, any old manufactuer will do. For what it's worth, Skyjacker is my favorite for the mass manufactuers kits.
