Modular V10 (6.8l)
When was excursion V10 plug blowout fixed?
Old Sep 20, 2007 | 09:42 AM
kevin.ford-trucks's Avatar
kevin.ford-trucks
Hi,
I'm looking to buy either a '00 or '02. One differentiator would surely be the risk of the '00 to have the plug blowout issue.
Is it quite certain that the problem was resolved on the '02? Or might this still be an issue.. thus not a differentiator in my decision?
Thanks much... been posting lots of Qs in the EXC forum.. but was suggested to post this one here!
Old Sep 20, 2007 | 09:54 AM
kevin.ford-trucks
Or reading here.. can there be preventative maintenance that makes this a non issue?
Old Sep 20, 2007 | 10:16 AM
kevin.ford-trucks
According to CARFAX, the '00 was manufactured on 4/27/00 and the '02 on 9/20/01. Do you suppose, then, they both have the same 4-5 thread head?
Old Sep 20, 2007 | 11:34 AM
dkf's Avatar
dkf
They should both have the short thread heads.
Keep the plugs torqued to proper specs, apply anti seize and the risk of plug blowout will be reduced if not eliminated.
Old Sep 20, 2007 | 02:27 PM
Fredvon4's Avatar
Fredvon4
The 2003 and up all have the deeper thread count but that still does NOT eliminate the steel plug in an aluminum head issue... It does make plug blow out it rarer then it was originally but even with the low thread count heads the plug blow out issue was very rare and most always tracked to too tight or too loose a plug...
Old Sep 20, 2007 | 03:37 PM
kevin.ford-trucks
excellent and timely info! thank you
so plug blow out is not a differentiator..
Old Sep 20, 2007 | 03:56 PM
kevin.ford-trucks
Ok.. so what torque should I use.. think I saw 30 ft-lbs?
Old Sep 20, 2007 | 04:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
14ft/lbs was the general consensus way back...
Someone recommends 30ft/lbs, a commercial plug blowout repairer, don't remember who... sounds very high to me.
Old Sep 20, 2007 | 06:13 PM
Fredvon4's Avatar
Fredvon4
If you use 30 foot pounds you run the risk of over torque and the predictable results...
168 inch pounds or 14Ft pounds is the recommended torque in the manuals
Based on engineering books I have, 14 ft ponds is right about the middle of the range that the hole diameter and thread count suggest... 12 ft pound (144 inch pounds) to 16 foot pounds (192 inch pounds) is the range for the dimensions I looked up assuming a hardened aluminum casting
inch pounds = foot pounds X 12
30 ft pounds would be around 100% over torque... you decide
Old Sep 20, 2007 | 09:19 PM
kevin.ford-trucks
Are those harbor freight torque wrenches accurate enough? I think I got their 1/2" and 3/8".
What add-ons do I need to get to those back 4 holes?
Old Sep 21, 2007 | 07:48 AM
Fredvon4's Avatar
Fredvon4
I use a 3/8th "click" type 100~300 inch pound torque wrench
I also use a 3/8ths ratchet wrench with short 3", medium 6", and long 9", 3/8th extensions and a wobble "U" joint with a "capture" type plug socket
YOU really need a source of compressed air to do a plug job on this motor
I blow out each hole then slightly loosen a plug, and before removing it all the way, blow out again...I do one plug at a time so to keep from blowing all the sand, mud, and crap into any open hole
Old Sep 21, 2007 | 08:03 AM
benr0's Avatar
benr0
Forced air is a must.
I used a shop vac as a blower with a duck tape solution from the blower tip to a 3/8 flexible hose left over from a tranny fluid change, fit right over the plug.
You won't believe how much stuff gets in the plug holes.
Old Sep 21, 2007 | 10:15 AM
kevin.ford-trucks
I got plenty of air (mostly hot) around my place ;-)
fordiesel69
Modular V8 (4.6L, 5.4L)
13
Jan 22, 2016 09:17 AM
xlt00
1997 - 2003 F150
17
Nov 6, 2006 11:53 PM
jake00
Car/truck Buying Advice
Jan 21, 2006 02:54 PM
westladog
Modular V10 (6.8l)
19
Oct 11, 2004 11:33 PM
79CEEJAY
Oct 18, 2002 08:27 PM
