Sorry for the stupid noob questions, but I gotta find out somehow.
I had esof on a 4.0l Ranger a while ago, rarely used it and then it crapped out when I needed it.
Only other 4wd drive experience is a couple of subarus.
I'm spec'ing a F250 for towing a trailer (6-8,000 lbs) and winter use. (daily driver is a Kawasaki Concours to keep the Carbon Karma in balance).
Assuming the 6 speed manual...
1. If I go for manual hubs, can I leave hubs unlocked and put transfer case in 4wd low for maneuvering a TT around the campground?
We're talking first and second gear here, not towing on the road. I figured the lower gear ratios would make maneuvering a lot easier.
2. If there's snow on the ground and the back roads are bad, I lock hubs and put it 4wd high. The main roads are ok, except maybe a bit wet. How bad is it to drive on relatively clean roads in 4wd. Maybe 7-10 miles, but up to 65-70 for short while on the highway.
3. If I lock hubs, the drive in 2wd, do I have to come to a dead stop to shift transfer case into 4wd high? Does tranny have to be in neutral? In gear, but clutched in?
2) yes, you can use it on pavement, but not for speeds over 40 mph(to me 30 is pushing it). IF you can do 60 mph, then the roads must not be that bad any more, and 2wd should be fine.
3) Yes, you can be rolling in gear and put the truck in 4 High.
IF it is esof, to put it in 4 lo with a standard you would need to stop, put it in neutral, AND push the clutch for 4 lo to engage.
Only thing I would add is if the truck had posi or L/S or a locker. Makes driving on ice/snow alot different than an open differential in 4WD. But there's no problem leaving the manual hubs locked when going from 2WD to 4WD, and back. Saves time getting in an out of the vehicle, whether you have manual shift t-case or electrical. I just wouldn't run on pavement at cruising speed for very long with the hubs locked in and in 2WD like stated, as it can increase the wear&tear on the hubs plus reduce mileage a tad. JSM84
You can leave the hubs locked all the time if you want most of the winter mine are. The increased wear and tear is minimal, and the MPG is about 1 MPG less with them locked. As far as going from 4hi to 4low, with a manual transfer case the transmission has to be in neutral.
