AC problems
Old Sep 19, 2007 | 08:36 PM
97-psd's Avatar
97-psd
AC problems
well I was drivin' home yesterday and noticed the ac wasn't working as well as it normally did, and then today I had very little cold air, funny thing was that when I was just idling it seemed like the air would get cooler then as I took off the coolness was lost again, I think it is probably just a slow leak somewhere, but I just wanted to check and see if there any 'normal' AC problems, I did a forum search but didn't come up with anything. thanks.
btw the rig is a 97 psd, cc, 5-speed.
Old Sep 19, 2007 | 08:42 PM
93f1505.0L's Avatar
93f1505.0L
Most likely low on refrigerant. From what you said it seems like the compressor is kicking on but make sure it is just incase. If it is not make sure you are getting power to it. If all checks out evacuate and recharge the system adding dye so you can find the leak.
jboard's Avatar
jboard
I would take it somewhere and have manifold gauge set hooked to it or borrow some gauges its the only way to tell whats going on.
Old Sep 19, 2007 | 09:09 PM
97-psd's Avatar
97-psd
thanks for the replies, I have a guy I use for AC service, I figure it is just low on refrigerant, I just wanted to make sure there weren't any typical issues that are associated with these trucks
Old Sep 20, 2007 | 06:10 AM
jboard's Avatar
jboard
When I got my truck a year and half ago my AC was warm I went to Autozone took 3-4 cans which meant almost empty, havent had a problem since. So a little R134a and youll be ready to go.
---------Jeremy
97-psd
Jul 22, 2016 05:59 AM
Fordin
2015 - 2020 F150
May 17, 2016 12:19 PM
green_95
28
May 13, 2016 12:44 PM
muneeb
Apr 25, 2016 07:45 AM
bcalhoon
May 9, 2011 04:35 PM
