390 miss need help
Old May 17, 2002 | 01:20 PM
bigoldblue's Avatar
bigoldblue
Post 390 miss need help
Hey all,
I've got a 71 f100 4x4 390 4bbl-edelbrock 600, 4spd and i've got a miss--not much of a miss at idle-a little rough. when accelerating it misses just enough to where you can hear it and feel it, not really bad though. I went through everything i could think of, new cap rotor, plugs, wires, air filter, fuel filters, installed pertronix w/coil, did compression check 135 all even. checked for vaccum leak w/carb cleaner everywhere, vaccum isn't good, fluctuates between 7-14 rapidly, and the plugs show signs of running a little rich- not fuel fouled or anything though. the truck runs great going down the road-no miss then. any suggestions?
thanks
david
Old May 17, 2002 | 03:58 PM
Ratsmoker's Avatar
Ratsmoker
390 miss need help
Make sure all of your coil wires and grounds are clean and tight.
Old May 17, 2002 | 06:04 PM
bigoldblue's Avatar
bigoldblue
390 miss need help
yeah, i checked that, and also checked the timing, and firing order
Old May 17, 2002 | 07:13 PM
canzus's Avatar
canzus
390 miss need help
You've either got a semi bad plug wire or plug,
or a sticky valve/bad lifter, as it's just at idle
I'm betting on the weak lifter...
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
Old May 17, 2002 | 07:21 PM
Flash's Avatar
Flash
390 miss need help
You have the indicator to look for with the bad vacuum. It can be several items from a cam going flat to a bad intake manifold. I would suggest pulling plug wires and narrowing it down to a specific cylinder. I had a 360 with a stock 4 bbl intake that had a crack between the heat for the carb and the intake runner, almost drove me nuts finding it. Also, just because you sprayed cleaner on top of the manifold doesn't mean there isn't a leak, it can leak on the inside.
Old May 28, 2002 | 11:31 AM
michaelws's Avatar
michaelws
390 miss need help
One possiblity that I can think of is that the valves might be too tight. What type of rockers are you using? Are they adjustable? If you do not have adjustable rockers and if the heads have been decked it you might need shorter pushrods.
Old May 28, 2002 | 08:36 PM
big block power's Avatar
big block power
390 miss need help
Old Jun 3, 2005 | 05:18 AM
dnooner16's Avatar
dnooner16
i agree with the intake... could be internally cracked... what do you have your timing set at? with the nylon-toothed cam timing gear, as old as the engine is, i would check to see if the teeth have worn off and see if the timing chain might have jumped a tooth or two... with timing retard/advance of a few degrees or so, you could get 7 or possibly all 8 cylinders to fire great at idle, but at part/mid throttle you could notice a misfire...
Old Jun 3, 2005 | 06:34 AM
William's Avatar
William
Try re-torquing the intake bolts! Should be 35fp with cast iron intake. Fluttering vacuum is an air leak. Do you have an EGR on this truck? Loose carb? Could be a lot of things but do the easy stuff first. My problem turned out to be the intake gasket!
Jonnylightning
Jun 8, 2017 07:32 PM
stinger57
Nevada Chapter
Dec 20, 2016 08:26 AM
77bronco87
Feb 8, 2015 10:32 AM
CMB1998
Modular V10 (6.8l)
Feb 6, 2014 08:00 AM
1973fordf-100
16
Nov 6, 2010 11:28 PM
